Visitor twlee2
Opencv Problem in SDx 2017.4
I am trying to capture video using cv::VideoCapture and my code is like below
#include <opencv2/opencv.hpp>
using namespace std;
int main(int argc, char **argv) {
cv::VideoCapture zed_cap(0);
cv::Mat img;
However, when I compile the code I get the following error:
main.cpp:(.text.startup+0x54): undefined reference to `cv::VideoCapture::VideoCapture(int)'
main.cpp:(.text.startup+0xa4): undefined reference to `cv::VideoCapture::retrieve(cv::Mat&, int)'
main.cpp:(.text.startup+0xcc): undefined reference to `cv::_InputArray::_InputArray(cv::Mat const&)'
main.cpp:(.text.startup+0xd8): undefined reference to `cv::imshow(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, cv::_InputArray const&)'
main.cpp:(.text.startup+0xf0): undefined reference to `cv::waitKey(int)'
main.cpp:(.text.startup+0xf8): undefined reference to `cv::VideoCapture::grab()'
main.cpp:(.text.startup+0x110): undefined reference to `cv::VideoCapture::~VideoCapture()'
main.cpp:(.text.startup+0x134): undefined reference to `cv::VideoCapture::~VideoCapture()'
collect2.exe: error: ld returned 1 exit status
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling 'aarch64-linux-gnu-g++ H:/Xilinx/work/zed/Release/src/main.o H:/Xilinx/work/zed/Release/_sds/swstubs/portinfo.o {-LC:\Xilinx\SDK\2017.4\data\embeddedsw\ThirdParty\opencv\aarch64\lib} -lopencv_core -lopencv_imgproc -L C:/Xilinx/SDx/2017.4/target/aarch64-linux/lib -LH:/Xilinx/work/zed/Release/_sds/swstubs -Wl,--start-group -Wl,--end-group -Wl,--start-group -lpthread -lsds_lib -lxlnk_stub -Wl,--end-group -o H:/Xilinx/work/zed/Release/_sds/swstubs/zed.elf'
sds++ log file saved as H:/Xilinx/work/zed/Release/_sds/reports/sds.log
ERROR: [SdsCompiler 83-5004] Build failed
I set the libraries as following:
Libraries (-l)
opencv_core
opencv_imgproc
Library search path (-L)
"C:\Xilinx\SDK\2017.4\data\embeddedsw\ThirdParty\opencv\aarch64\lib"
It seems a linking problem but I am not sure how to solve this.
Please advise!
Thank you in advance.
Re: Opencv Problem in SDx 2017.4
Hi @twlee2
Please check xfopencv once.
https://github.com/Xilinx/xfopencv
Best Regards,
Nutan
Hi @twlee2
Please refer below forum post
https://forums.xilinx.com/t5/SDSoC-Environment-and-reVISION/ZCU104-video-capture-with-opencv-library-issue/td-p/891127
Best Regards,
Nutan
Visitor twlee2
Thank you for your response.
I checked that message but I am still not sure in windows what is correct library search path.
Is "C:\Xilinx\SDK\2017.4\data\embeddedsw\ThirdParty\opencv\aarch64\lib" this a right library search path?
Obviously this doesn't work for me in windows.
Please advise!
Hi @twlee2
Best Regards,
Nutan
