Parallel work-items?
Hi All,
As I understood from UG1207 document. SDAccel adds a conceptual loop nest around a kernel code to traverse the entire work-items in a work-group.
Then pipelining is the technique to optimise the execution of these nested loops.
I am wondering if there is any way to run work-items in parallel (not pipelined). For example unroll the conceptual loop nest.
Mohammad
Re: Parallel work-items?
Hi Mohammad,
Currently, there is no xcl unroll attribute for work items.
You can use the opencl unroll attribute on a loop containing your kernel function as shown in this example:
https://www.xilinx.com/html_docs/xilinx2016_3/sdaccel_doc/index.html?q=/html_docs/xilinx2016_3/sdaccel_doc/topics/kernel-optimization/con-loop-unrolling.html
Or this complete example:
https://github.com/Xilinx/SDAccel_Examples/tree/master/getting_started/kernel_opt/lmem_2rw_ocl
Keep in mind with an FPGA you are not mapping your application to a fixed architecture. The conventional notion of process elements does not exist on the FPGA until you create them.
In some cases, the 3 nested loops can be helpful. In the case of unrolled work items, you can use __attribute__ ((reqd_work_group_size(1, 1, 1))) or clEnqueueTask then define your own index space loops and unroll them as you see fit.
Many of the examples on GitHub show this style of implementation.
Best,
-Dutch
Hi Mohammad,
Best,
-Dutch
