Profiling information obtained using sw_emu is random
I am trying to measure the execution time of the kernels using aws-fpga using sw_emu. Everytime i run the same code and check the profile summary i get different timings.
Eg:
1st run: 2.3ms
2nd run: 8ms
3rd run: 13ms
Why is the execution time change for the same code.
回复: Profiling information obtained using sw_emu is random
sw_emu uses CPU to do emulation for sw compiling result. It highly depends on CPU load. Besides, the time measured in sw_emu is less meaningful than hw_emu. You may try hw_emu to see any difference.
brucey
brucey
