Observer cole.jepson
Retarget IP error
As you can see from my previous questions, I'm trying to generate a custom platform using Vivado 2016.2 and SDSoC 2016.2. I have nearly got it working I think but I'm getting a strange error saying:
ERROR: [BD 5-336] This command cannot be run, as the BD-design is locked. Locked reason(s):
* BD design contains locked IPs. Please run report_ip_status for more details and recommendations on how to fix this issue.
List of locked IPs:
XADCTest2_processing_system7_0_0
XADCTest2_rst_processing_system7_0_100M_0
In the vivado.log file within my debug session it says that the processing system and processing system reset need an "IP board change Retarget IP" (first picture) but when I go to Vivado and use the tcl command report_ip_status it says that no changes are need on these IP and they are the same version (second picture).
What could cause this discrepancy?
Re: Retarget IP error
The "locked IP" message usually means that the Vivado IPI tool thinks the IP versions in your design are not
the latest version. If the platform Vivado project IP versions are the latest in that release, you shouldn't see this
message and the report_ip_status command normally tells you which IP versions are not up to date.
It's possible that there a differences in IP versions between the Vivado 2016.2 installation (separate from SDoC)
and the SDSoC 2016.2 installation (which contains it's own copy of Vivado). I wouldn't expect this to be the case.
If you use the Vivado tool found in the SDSoC installation to create your Vivado project for the platform, you
shouldn't see this message. Maybe you can open the project in the SDSoC 2016.2 Vivado and update any Ip
versions if it thinks it is out of date. On Windows the SDSoC Start menu has Vivado sub-menus, or on the
command line you can use an SDSoC Terminal (Windows) or shell where you ran the SDSoC settings64.csh or .sh
to set the environment (Linux) to start vivado.
If you did everything with the SDSoC 2016.2 Vivado, something strange is happening.
I'm going to try loading the newest version of Vivado...maybe this will fix the problem? I don't know...
You are right. I must not have used the Vivado that came with SDSoC or something. After installing Vivado 2016.3, these errors went away but other errors have appeared (you will see those in a minute in another thread).
I think you should check the system and the try to use the correct ip address
