SDAccel 2017.4 Abnormal program termination (11)
Hi guys,
I am working on SDAccel 2017.4. when I compile my OpenCL kernel module, tool will generate error message of "Abnormal program termination (11)" at vivado_hls.log. I have attached the hs_err_xxx.log file in here.
What can be the issue for this?
Re: SDAccel 2017.4 Abnormal program termination (11)
Hi, @allien ,
You can refer to the below link for the regulation:
https://www.khronos.org/registry/OpenCL/sdk/1.0/docs/man/xhtml/vloadn.html
Hi, @allien ,
Which operating system are you using?
Can you complete C-simulation properly?
Could you try to compile the kernel code directly in HLS?
Hi @hongh
thanks for your response.
I was able to sort out the issue. In my module I have below function
uint4 data = convert_uint4(vload4(A, B));
A is int and B is unit8_t (= unsigned char)
When I assign Zero into A, then error will not occurred. Is there any regulation A should have?
A is calculated with an arithmetic operation
centos at AWS. C4 instance
Hi, @allien ,
