SDAccel 2018.3 Example RTL Adder Pipes : not working for DATA_SIZE > 4096
I synthesized a slightly modified version of the SDx example design "RTL Adder Pipes", removing the adder to achieve a simple loopback.
When using the attached code with DATA_SIZE=32 it works fine, when using DATA_SIZE=4096 or higher the execution freeze line 217.
Any idea why?
Re: SDAccel 2018.3 Example RTL Adder Pipes : not working for DATA_SIZE > 4096
My bad, the "q.finish()" after write was blocking the next read operation in case of DATA_SIZE > 4096.
Removing it fixed the issue
