Visitor yugi_nhc
SDSoC ZCU102 execution context is running error
Hi, I'm having problems when working with ZCU102 using SDSoC 2018.2
I'm doing a simple matrix multiplication example on SDSoC (2018.2) using ZCU102 and ZCU104. The example works well with ZCU104, but following error always occurs when using ZCU102.
My ZCU102 board is revision 1.1 labeled 0432055-05 ~ .  I think that the problem is related to DDR4 DIMM changing as discussed on AR-71961
Could you please help me to solve this problem on SDSoC?
Thank you
Re: SDSoC ZCU102 execution context is running error
Hi @yugi_nhc
Please refer the below post to fix the issue:
https://forums.xilinx.com/t5/Evaluation-Boards/Hello-World-on-ZCU102/m-p/959547?collapse_discussion=true&filter=location&location=category:XlnxProd&q=71961&search_type=thread
Let me know if this helps.
Vijoy Sunil Kumar
Product Applications Engineer
- Don't forget to reply, kudo and accept as solution
Hi @yugi_nhc
Vijoy Sunil Kumar
Visitor yugi_nhc
Thank you so much
