Participant christian.moncada
SDSoC header files not found consistently throughout project
I have an SDSoC project that targets a custom platform. That platform is using a BSP defined when making the software components in SDK. I added the BSP include directory in the build settings for the project, but the header files located in that directory are not always found. In my main file and in another file I include "xv_tpg.h", but the compiler only finds it for the main file. When trying to compile the second file I get a "file not found" error. I don't know why it would find the header for one of the files but not both. I've double checked for typos and looked at the compilation log to make sure the main file compiled without errors.
Re: SDSoC header files not found consistently throughout project
I solved my own problem. I have a mixture of .c and .cpp files in my project (inherited code) and I only updated the SDS++ compiler with the new include directory. I added the include path to the SDSCC compiler and it now finds the header files.
Hi @christian.moncada
This happens everytime you build the project?
Best Regards,
Nutan
Yes. I've tried cleaning and rebuilding a couple times with the same result.
Please let me know SDSoC version.
Also, is it possible to share the full log?
Best Regards,
Nutan
2018.1
