Observer calex
SDaccel 2018.2 : vadd example : make check problem
hi all,
i'm following the
https://github.com/Xilinx/SDAccel_Examples/tree/master/getting_started/misc/vadd
example. Using the GUI, it's ok but now i'm trying to use the makefile.
I'm reading the README.md and try the following commands :
make all TARGETS=sw_emu DEVICES=xilinx:kcu1500:dynamic REPORT=estimate
make check TARGETS=sw_emu DEVICES=xilinx:kcu1500:dynamic
the make check fails :
Error: Failed to find Xilinx platform
the result is the same if i try :
export LD_LIBRARY_PATH=$XILINX_SDX/runtime/lib/x86_64/:$LD_LIBRARY_PATH
export XCL_EMULATION_MODE=sw_emu
emconfigutil --platform 'xilinx:kcu1500:dynamic' --nd 1
./vadd
find attached the log file.
any idea ?
C.Alexandre
Observer calex
Re: SDaccel 2018.2 : vadd example : make check problem
hi all,
if you are using (as me) SDaccel 2018.2
under Ubuntu 16.04 LTS, you have to modify
in the local github clone of SDAccel examples
examples/libs/opencl/opencl.mk
line 14
opencl_LDFLAGS=-L$(OPENCL_LIB) -L$(SDA_LIB) -lxilinxopencl -pthread
then
works properly.
regards C.Alexandre
Hi @calex,
  1. Please create a file and it's name should be xilinx.icd and content should be libxilinxopencl.so .
  2. setenv OPENCL_VENDOR_PATH <directory where xilinx.icd file is present> (cshell) in case of bash use export command to set the environment variable accordingly.
Kali
Hello @calex,
You can run the following command to get a list of available platforms for the given Vivado release:
  xocc --list
For my 2018.2, I get the following:
xilinx_kcu1500_dynamic_5_0
xilinx_vcu1525_dynamic_5_1
Chris
Observer calex
Hi Kalib,
i have made a copy of libxilinxopencl.so and rename it to xilinx.icd.
i can find 3 versions of libxilinxopencl.so. I have checked all :
alex@bar:~/workspace/examples/getting_started/misc/vadd$ echo $OPENCL_VENDOR_PATH
/home/alex/Xilinx/SDx/xilinx.icd
alex@bar:~/workspace/examples/getting_started/misc/vadd$ file /home/alex/Xilinx/SDx/xilinx.icd
/home/alex/Xilinx/SDx/xilinx.icd: ELF 64-bit LSB shared object, ARM aarch64, version 1 (GNU/Linux), dynamically linked, BuildID[sha1]=3a26a1d32678174c3926e7bda0547911d4ab6eb7, not stripped
/home/alex/Xilinx/SDx/xilinx.icd: ELF 32-bit LSB shared object, ARM, EABI5 version 1 (GNU/Linux), dynamically linked, BuildID[sha1]=9de687511f662f3fe4b9b0e185e20811ecb4d554, not stripped
/home/alex/Xilinx/SDx/xilinx.icd: ELF 64-bit LSB shared object, x86-64, version 1 (GNU/Linux), dynamically linked, not stripped
in all cases, the failure is the same :
alex@bar:~/workspace/examples/getting_started/misc/vadd$ make check TARGETS=sw_emu DEVICES=xilinx:kcu1500:dynamic
/home/alex/Xilinx/SDx/2018.2/bin/emconfigutil --platform xilinx:kcu1500:dynamic --nd 1
****** configutil v2018.2 (64-bit)
  **** SW Build 2258646 on Thu Jun 14 20:02:38 MDT 2018
    ** Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
INFO: [ConfigUtil 60-895]   Target platform: /home/alex/Xilinx/SDx/2018.2/platforms/xilinx_kcu1500_dynamic_5_0/xilinx_kcu1500_dynamic_5_0.xpfm
emulation configuration file `emconfig.json` is created in current working directory
XCL_EMULATION_MODE=sw_emu ./vadd
../../..//utility/check.mk:60 : la recette pour la cible « check_sw_emu_xilinx_kcu1500_dynamic_check » a échouée
make: *** [check_sw_emu_xilinx_kcu1500_dynamic_check] Erreur 1
regards
C.ALEXANDRE
Hi @calex ,
1. Create a directory at following location on your machine.
/home/alex/Xilinx/SDx/xilinx_icd
2. Copy the xilinx.icd file at  /home/alex/Xilinx/SDx/xilinx_icd
3. setenv OPENCL_VENDOR_PATH /home/alex/Xilinx/SDx/xilinx_icd
When you do echo $OPENCL_VENDOR_PATH it must point to the directory where xilinx.icd file is present but not the xilinx.icd file itself (as per your previous log).
Alex: i have made a copy of libxilinxopencl.so and rename it to xilinx.icd.
You need not rename this way instead create a file with xilinx.icd file name.
Add libxilinxopencl.so as content of xilinx.icd and save it.
Kali
Observer calex
hi kalib,
i'm sorry, but i don't understand clearly the procedure :
1)  create a file with xilinx.icd file name.
2) Add libxilinxopencl.so as content of xilinx.icd and save it.
what do you mean exactly (these are binary files) ?
regards
calex
Observer calex
and should i use the x86-64, version ?
regards
calex
Observer calex
hi all,
line 14
then
works properly.
regards C.Alexandre
Hi @calex,
Good to know that provided fix works for you based on our offline communication.
I am sharing the solution that I provided to you offline here to benefit future users of SDAccel 18.2 with Ubuntu 16.4 environment.
Hi Alex,
Please try this
At following location in your local github clone of SDAccel examples --> https://github.com/Xilinx/SDAccel_Examples/blob/master/libs/opencl/opencl.mk
Basically replace -lOpenCL  with -lxilinxopencl .
Kali
