Observer 662ldd
SDx command not found
Hi I can open SDx on my via GUI Desktop, but when I try to start SDx using command line. It tells me that the command is not found. What may be the problem?
回复: SDx command not found
You need to set up the environment by sourcing the following files.
C Shell:
source <SDx_INSTALL_DIR>/settings64.csh
source <XRT_INSTALL_DIR>/xrt/setup.csh
Bash:
source <SDx_INSTALL_DIR>/settings64.sh
source <XRT_INSTALL_DIR>/xrt/setup.sh
C Shell:
Bash:
