Visitor firatto
Unsupported pointer reinterpretation error during Hardware emulation ..
This is the outline of kernel code I'm trying to compile.
//kernel ....
ulong PState[8];
for (uint i = 0; i < 4; ++i)
   ulong AH[8], AM[8];
   for (int x = 0; x < 8; ++x) {
       AH[x] = AM[x] ^ PState[x];
//##end kernel
Error message is :
unsupported pointer reinterpretation from type '[8 x i64]*' to type 'i512*' on variable 'PState'.
I've tried to use temp ulong values (for xor expression )  but same error ...
Visitor firatto
Re: Unsupported pointer reinterpretation error during Hardware emulation ..
I think I solved problem by changing all reinterpratations with array access ( calculating pointer math.. ).
It's interesting that a compiler can repartition arrays, unroll loops and does plenty of other things but not make pointer reinterpretation ( simple math based types length )..
Anyways thank you for help..
Hi Firatto,
   I tried this myself really quickly without an error.
Can you take the code in question,and make a fully build-able kernel code snippet that I can just compile and get the same error?
The error looks like you are using your pointer PState which is 64 bits, with some value elsewhere that is 512 bits.
I don't think: AH[x] = AM[x] ^ PState[x]; should be the line that does that, as it's not using the pointer, it's all the same size array with the same size elements in it.
Do you happen to have something like a uint16 used in your code?
If at first you don't succeed, try redefining success?
Visitor firatto
Hi Evant,
thanks for reply,
You're right , I was trying to simple kernel just the code give error, and code compiled ..
My final thought is during synthesizing returned errors may not point exact location.
I'll try to send full code ( it's not public, need to ask seniors before that ).
Is it possible to send it privately.
Thanks again for help.
Yeah, there is a way to direct message me. If that doesn't work let me know.
Visitor firatto
