Observer kikd180
Vitis 2019.2: Cannot create ZCU111 standalone platform on Windows10
Hello
I'm trying to create ZCU111 standalone application and platform, using  XSA file from rdf0476-zcu111-rf-dc-eval-tool-2019-2.
But, "Create Platform" has failed why below message.
Failed to create platform.
Could not create platform for standalone and psu_cortexa53_0
Failed to generate the bsp sources for domain.standalone_domain
Details: Failed to generate cmake files Windows.
ERROR: [Hsi 55-1545] Problem running tcl command ::sw_rfdc_v7_0::generate : Failed to generate cmake files Windows.
while executing
"error "Failed to generate cmake files Windows.""
(procedure "generate_libmetal" line 86)
invoked from within
"generate_libmetal"
(procedure "::sw_rfdc_v7_0::generate" line 7)
invoked from within
"::sw_rfdc_v7_0::generate usp_rf_data_converter_0"
ERROR: [Hsi 55-1442] Error(s) while running TCL procedure generate()
Other platform(using preinstalled XSA)  can created.
What happened is this??
Regards.
Re: Vitis 2019.2: Cannot create ZCU111 standalone platform on Windows10
Hi @kikd180,
This issue occurs on Vitis 2019.2 for windows platform when adding LibMetal/OpenAMP to BSP.
We are aware of this issue and it will be fixed in the next release.
To fix the issue from your side, please try to replace the content of the following files with the below code:
- <XilinxInstall>\Vitis\2019.2\data\embeddedsw\ThirdParty\sw_services\libmetal_v2_0\src\run_cmake.bat
- <XilinxInstall>\Vitis\2019.2\data\embeddedsw\ThirdParty\sw_services\openamp_v1_5\src\run_cmake.bat
if not "%HDI_APPROOT%" == "" (
%HDI_APPROOT%\tps\win64\cmake-3.3.2\bin\cmake.exe %* 2>&1
) else (
if "%XILINX_SDK%"== "" (
%XILINX_VITIS%\tps\win64\cmake-3.3.2\bin\cmake.exe %* 2>&1
) else (
%XILINX_SDK%\tps\win64\cmake-3.3.2\bin\cmake.exe %* 2>&1
Best regards,
Abdallah
Observer kikd180
If I remember correctly, Vitis on Linux was able to create that platform.
So, I think this issue occurs only Windows.
Hi @kikd180,
) else (
) else (
Best regards,
Abdallah
Observer kikd180
Hello @abouassi.
This issue solved by your workaround.
Thank you for mention!
Regards.
