Xilinx SDSoc fails to open
I had a new installation of Xilinx SDSoC and it did open once but than after it just fails to do so, with below error prompt.
[user@machine ~]$ sdx -workspace . &
[1] 26720
[user@machine  ~]$
****** Xilinx SDx Development Environment
****** SDx v2018.3 (64-bit)
**** SW Build 2405991 on Thu Dec 6 23:37:15 MST 2018
** Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
Launching SDx with command /wv/scratch-user/XilinxSDSoC_2019/SDx/2018.3/eclipse/lnx64.o/eclipse -data . -vmargs -Xms64m -Xmx4G -Dorg.eclipse.swt.internal.gtk.cairoGraphics=false --add-modules=ALL-SYSTEM --add-modules=jdk.incubator.httpclient --add-opens=java.base/java.nio=ALL-UNNAMED --add-opens=java.desktop/sun.swing=ALL-UNNAMED --add-opens=java.desktop/javax.swing=ALL-UNNAMED --add-opens=java.desktop/javax.swing.tree=ALL-UNNAMED --add-opens=java.desktop/javax.swing.plaf.basic=ALL-UNNAMED --add-opens=java.desktop/javax.swing.plaf.synth=ALL-UNNAMED --add-opens=java.desktop/com.sun.awt=ALL-UNNAMED --add-opens=java.desktop/sun.awt.X11=ALL-UNNAMED &
java.lang.RuntimeException: Error initializing storage.
at org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(EquinoxContainer.java:70)
at org.eclipse.osgi.launch.Equinox.<init>(Equinox.java:31)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:303)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:239)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
Caused by: java.io.EOFException
at java.base/java.io.DataInputStream.readInt(Unknown Source)
at org.eclipse.osgi.storage.Storage.loadGenerations(Storage.java:1160)
at org.eclipse.osgi.storage.Storage.<init>(Storage.java:137)
at org.eclipse.osgi.storage.Storage.createStorage(Storage.java:85)
at org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(EquinoxContainer.java:68)
... 11 more
and console msg as See log file.
Need Help to fix these issues,
1. Where can I find a log file?
2. I am running on Redhat 7.4 with
java version "1.7.0_65"
OpenJDK Runtime Environment (rhel-2.5.1.2.el6_5-x86_64 u65-b17)
OpenJDK 64-Bit Server VM (build 24.65-b04, mixed mode)
Any incompatibilities?
Re: Xilinx SDSoc fails to open
Hi @harish-anil
Have you tried re-installing? If that doesn't work, try deleting the .metadata directory in you rworkspace.
Let me know if this helps.
Vijoy Sunil Kumar
Product Applications Engineer
- Don't forget to reply, kudo and accept as solution
Hi @harish-anil
Vijoy Sunil Kumar
