Visitor alterade2
disable loop pipelining
Sdaccel document mentions that loop will be automatically unrolled under some conditions. The attribute "xcl_pipeline_loop" enables loop pipelining.
Is there a pragma or attribute that a user can use to disable loop pipelining ?
I hope the question makes sense.
Re: disable loop pipelining
Hi @alterade2
You can use following commandline switch:
--xp "param:compiler.enableAutoPipelining=false"
But this will apply to all loop, so with this switch, user should apply explicit pipeline pragma if needed.
Following Git example is using this switch (See the Makefile):
https://github.com/Xilinx/SDAccel_Examples/blob/master/getting_started/debug/debug_printf_ocl
-Heera
Hi @alterade2
-Heera
Visitor alterade2
