Participant avinash.pisal.s
AXI Chip2Chip
How to include AXI Chip2Chip IP in XILINX ISE LogicCore generator list?
Scholar markcurry
Re: AXI Chip2Chip
The source RTL code (and docs) is in your Xilinx install tree.  Just instanciate it and go.  Forget coregen/edk/xps/ whatever other silly wizard/etc.
i.e.
Xilinx/14.5/14.5/ISE_DS/EDK/hw/XilinxProcessorIPLib/pcores/axi_chip2chip_v3_00_a
I've done this with a lot of the Xilinx code - but not with this one specifically.
Mark
Re: AXI Chip2Chip
It is EDK based core earlier and now it  was moved to Vivado,   I believe it  cannot be included  in coregen list .
V anitha.
Re: AXI Chip2Chip
Thank you Anitha,
I am trying to interface two Artix 7 Boards through AXIChip2Chip,one FPGA is Master and other is slave,
for slave fpga i not not using any embedded processor or controller,so
I create project for slave FPGA in XPS and generated .ngc for AXIChip2Chip, Than i added .ngc in ISE project for interfacing with my vhdl modules.
with above procedure will AxiChip2Chip work on slave side or any other method present to design AXIChip2chip based system with ISE?
Scholar markcurry
Re: AXI Chip2Chip
i.e.
Mark
Re: AXI Chip2Chip
Thank Mark,
It was a great Help.
