Analysing system monitor in chipscope(ILA)
With sysmon one can monitor temperature and voltage of FPGA. Thats clear.
There are several voltages parameters in ILA shown as in screenshot attached. I would like to know, is there any document describing which voltage is what?
I am using xcvu3p and would like to see vref(0.9v) of bank 44 and bank 47 needed for IO standard SSTL18_I_DCI. which one is vref there?
Furthermore is there any way to see if DCI also set in the bank or not?
Hi @fpgalearner,
It looks like to manage the Vref for specific banks, you need to use the System Management Wizard IP.
Please take a look at the document System Management Wizard v1.3 - PG185. On page 65, you can see the following information:
You can also find some more information about the XADC in the document UltraScale Architecture System Monitor User Guide - UG580.
Andre Guerrero
Product Applications Engineer
