BAD LINK in Xilinx® Training on ChipScope Pro and Core Generator
Were you aware that the first link in Xilinx® Training on ChipScope Pro and Core Generator ("ChipScope Pro Software Overview (with Labs)") points to the same place as the second link, which doesn't reference ChipScope whatsoever?
I corrected the link.
Can you please check now and confirm?
Vinay
But it does seem the the image link works.  So please fix the text link.
image link and the text link both are working fine for chipscope pro software overview. can you recheck and let us know.
--Krishna
Nope, not for me.  Please allow me to clarify.
This forum has a single thread locked to the top.  When I click on it, I go to a page:
http://forums.xilinx.com/t5/Design-Tools-Others/Xilinx-Training-on-ChipScope-Pro-and-Core-Generator/td-p/135152
On that page, when I mouse over the image at left, I see at the bottom of my browser the correct link (http://www.xilinx.com/training/fpga/chipscope-pro-training-video.htm).  I've marked that "CORRECT" in the image attached below, highlighted yellow.  However, when I mouse over the heading, I get the wrong link (http://www.xilinx.com/training/fpga/core-generator-software-system-video.htm).  It's the same as the Core Generator Software System.  I've marked this "WRONG" in the image attached below.  And, of course, clicking rather than mousing over leads to the wrong page.
I have verified both the links and found them working correctly. In any case clicking on either of the image or heading will open the same link as below
You can either try with different browser or clear the cache of current browser and give a try.
Ashish
You're kidding!  It's got to be you, not me.  I just cut this link:
from my Chrome browser and put it in my IE browser, which has never been ther before.
I moused over the "ChipScope Pro Software Overview (with Labs)" link.  I also did a copy shortcut.
I get this link http://www.xilinx.com/training/fpga/core-generator-software-system-video.htm
which is the WRONG LINK.
I emailed the link to an associate and tried it on their totally different computer that's never been here.
Same problem.
Yep, it's you, not me...
Vinay
yippie!  Now it's right.
