gus50310
Beginner Debug ?...Forcing input HI
I seem to have got though simulation and some of the debug of my first project.   With the debug items that use the clock I get the debug output I would expect.  But want to force a marked debug signal HI so I can check if I am latching it in my block.  I can not find any refences how this is done.
Attached is a image of the circuit.  If you have any suggestions or questions please let me know...Thanks
Gus50310
vuppala
Hello @gus50310
The suggestion is to use VIO core for providing the inputs to the design.
Check this product guide of VIO core: http://www.xilinx.com/support/documentation/ip_documentation/vio/v3_0/pg159-vio.pdf
Vinay
gus50310
I suppose I should have indicated I am using the Vivado 2015.3 tool set
Gus50310
vuppala
Hello @gus50310
Vinay
yashp
gus50310
Hi vappala
Thanks for the reply.  I just have not had a chance to check it out yet.
Thanks....Gus50310
gus50310
Hi yashp
Thanks....Gus50310
arpansur
Hi @gus50310,
Please go through Lab-3 of following link to get more information on using VIO core
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_2/ug936-vivado-tutorial-programming-debugging.pdf
Please let us know the outcomes after trying the above suggestions. Also let us know if you are facing any issues with the flow.
Arpan
Arpan
gus50310
HI vuppula - yashp - arpansur
After gathering the infromation I gleaned from looking at all the suggestions I believe I have the debug setup using the VIO IPs to confirm the logic is working the way I want.
Thanks....Gus50310
