Board not found on the vivado tool
Actually I can't find the board "Zynq-7 TE0720-02-2IF" on vivado 2018.2,I wonder if there is anyway to add it !!
Thanks for the support.
@ottmann,
you'lll need to create and add the board files to Vivado as described in UG895.
@ottmann,
