Visitor dalezz
Can Vivado calculate a time interval power based on SAIF file?
Hi everyone,
Recently, I need to do some power accurate power estimation for my FPGA design. The key idea is, I wanna calculate a time interval power. For example, the time interval from 10th cycle to 20th cycle, this 10 cycles time interval average power  for an adder design.
Below is what I do:
1. Start post-implementation function simulation
2. Run to a specified time, such as 10ns
3. Open_saif
4. Log_saif
5. Run another 10ns, to 20ns.
6. Close_saif
7. Report power using this SAIF
Does it work? I mean, SAIF files provide the toggle rate for every recorded signal during simulation, so ideally I can get the power number during 10ns~20ns, but I am not sure about how SAIF file record signal, only 10ns~20ns? Or 20ns?
Looking forward to your reply.
DaleZz
Teacher muzaffer
Re: Can Vivado calculate a time interval power based on SAIF file?
@dalezz saif records cumulative toggle counts for each recorded element so if run the simulation for 10ns (from 10ns to 20ns) you should get all the transitions in between.
Teacher muzaffer
Visitor dalezz
Thank you, @muzaffer. So, that means my operations are correct? The saif would not record first 10ns transitions?
