finish0404
Change version of IP core in the core generator of ISE
Hi :
I have encountered the trouble mentioned by the following ULR:
https://forums.xilinx.com/t5/Design-Tools-Others/coregen-fails-with-ICON-1-06a/td-p/818636
I saw it and thought the solution was to change the version of ip core (iLA and iCon) . Like this URL:
https://forums.xilinx.com/t5/Design-Tools-Others/import-ise-xps-project-to-planahead/td-p/685447
Where can modify the IP version in the core generator?
finish0404
I have already solved it.
Right click top entity of my project.
Select New source.
Select IP and key in file name and click next.
"Toggle All IP version"(as picture)
I have successfully generated icon and ila after using above settings.
finish0404
Select New source.
