manh_et2
ChipScope Analyzer: ILA signals not listed.
Hi everyone,
I've a ChipScope project which works on my laptop, however, on another PC, all the desired signals couldn't be listed.
I've tested 2 versions 9.2 and 10.1, none of them works. Even the re-installation can't fix it.
Thank  you for any help.
ywu
All you need to do is to save the project on your laptop and then copy the project file (.cpj file) to the other PC. You then open the project from Chipscope Analyzer running on the PC.
Cheers,
Jim
Cheers,
Jim
manh_et2
Thanks for your suggestion,
but I don't want each time to start a new project in my laptop and tranfer it to PC.
I prefer to solve the problem in the PC, like that I can let it synthesize for long time and do everything else in my laptop.
To me, tt seems the problem of USB Cable, since I've installed with the same disk Xilinx.
