Visitor namnninh
ChipScope Engine Tcl interface
Hi;
   I am using Chipscope Engine TCL interface to write (csevio_write_value) to FPGA and to receive (csevio_read_values) hex values from FPGA through VIO.
   I found Zero values are padded  (ex: 00002A3B) to returned value from TCL routine inputTclArray ().
  My question is how to remove all padded values from hex number (ex. 0x2A3B).
 Any helps are apprecicated.
NN
Re: ChipScope Engine Tcl interface
It depends on what you want to do with the hex number. If you want to use it for further numeric calculation, you can simply pre-pend string "0x" to it. e.g
set hex_str "00002A3B"
set hex_num "0x"
append hex_num $hex_str
set hex_num_plus_1 [expr {$hex_num + 1}]
Cheers,
Jim
Visitor namnninh
Hi;
  Thank you for your quick response to my question.
   Sorry, my question is not clear. I don't want to append 0x in the hex string.  Instead, I want to remove all 00 from a number (ex. 00002A3B ). So,  I only have a value(2A3B). This can help me to compare input file and output file since input values in the input file don't contain padded zero.
NN
set padded_hex_str "00002A3B"
regsub {^(0+)} $padded_hex_str "" hex_str
The hex_str will have padded "0" removed.
Cheers,
Jim
Cheers,
Jim
Visitor namnninh
Hi Jim;
 I tried on the command shell. It works.
 I applied your method to my program. I found value:ff or oo are padded again in a couple places,
 Below is the program which  read  numbers (2 or 3 bytes) from image file and sen to FPGA and loop back. Returned values are captured and written in binary number to output file.
 Hopefully, you can help me to identify this problem in my program.
Thank you very much.
Nam
Ex: input file (read 2 bytes at a time)
        13 30 45 3f 3d 3a 95 f3 ec e3 ce bb a6 98 72 57
        51 53 5e 5b 4b 4a 4c 46 46 44 4f 4f 4b 49 49
      output file:
         13 30 45 3f 3d 3a ff ff 95 f3 ff ff ec e3 ff ff
         ce bb ff ff a6 98 72 57 51 53 5e 5b 4b 4a 4c 46
program:
    set infile [open "inputData.dat" r]
    set outfile [open "dataOut.dat" w]
    fconfigure $infile -translation binary
    fconfigure $outfile -translation binary
while {![eof $infile]} {
#read 2 bytes from a file
     set line [read  $infile 2]
     binary scan $line H* value
# write a v value
     set outputTclArray(AsynOut) $value
     csevio_write_values $handle $coreRef outputTclArray
#read back
    csevio_read_values $handle $coreRef inputTclArray
    regsub {^(0+)} $inputTclArray(AsynIn) "" hex_str
# convert to binary number
    set bin [binary format H* $hex_str]
# write to a file
    puts -nonewline $outfile $bin
Looks like your data are always 16 bits and sign-extended to 32 bits (prepend 0's for positive number and 1's for negative number). If that's the case, a simpler solution would be just get the last 4 characters from the return values.
set hex_str [string range $padded_hex_str 4 7]
Cheers,
Jim
Visitor namnninh
Hi;
  I change different string range to allow different input data feed into the FPGA and collect them at the output port.
 It works perfectly. The output data file is identical to the input image data file.
Thank you for your help.
Nam
