Participant bmarsolais
ChipScope Pro Software Overview (with Labs) and Missing Signal mhertz_count<5>
I'm going through the ChipScope Pro Software Overview (with Labs) video and following the directions in the lab1_Insertflow instructions.  On page A-10, it says to assign mhertz_count<0:5> to TP2 ( trigger port 2) channels 0:5.  However, when I do a search for "mhertz_count*", only bits 0:4 show up.  I checked the source code and this signal is defined as 0:5.  Why does mhertz_count<5> not show up in the ChipScope Select Nets screen?
Thanks, Bob
Scholar pratham
Re: ChipScope Pro Software Overview (with Labs) and Missing Signal mhertz_count<5>
in case of ise open the technology schematic and search for the mhertz_count. in your case signal is getting trimmed off.use keep attribute or(S attribute) to avoid trimming of the signal.
Prathamesh
-Pratham
Scholar pratham
Prathamesh
-Pratham
Please provide the User Guide link you are using so that we can cross check (as it is a tutorial file, we need to check the trimming)
Debraj
I am using the zipped files downloaded using the link on your ChipscopePro online traing video webpage.  See the following link:
http://www.xilinx.com/training/free-video-courses.htm
The zip file is chipscope_lab_files_v12.zip
Thanks, Bob
Scholar pratham
HI
Thanks for the link and i have looked into that lab files.as i told you signal was getting trimmed off just apply keep constraint will solve your problem.
attribute keep : string;
attribute KEEP of mhertz_count: signal is "TRUE";
Pratham
-Pratham
