Visitor crjohnson11
Chipscope vs Vivado Debugger compile times
I have to use Vivado for a new design because the version of the Logicore IP that works for Artix designs is only available under Vivado.  In debugging the design, I noticed that just adding debugging for a small number of signals (8) adds about 5 minutes to the compile time for the design.  Since the design compiles in 5 minutes with no logic analyzer that is a 50% decrease in productivity!!!  I don't recall that Chipscope added this kind of overhead to the designs under ISE.
Has anyone else had this kind of SLOW experience with Vivado compile times when using the logic analyzer?
Re: Chipscope vs Vivado Debugger compile times
Chipscope ISE and Vivado Logic Analyzer are separate tools. If you are using the GUI for Logic Analysis where you are finding higher runtime, try running the same in Batch Mode using TCL script which uses less memory and improves runtime. In case you are fine with 5 mins of runtime with GUI you can avoid going to the Batch Mode.
Debraj
