hardwareheini
Create x1 MCS-File with PROMGEN instead of x8
I want to create a .MCS-File from my .BIT file using PROMGEN. The creation of the file works, but iMPACT delivers an error when I try to program this file into the flash:
The 'Data Width' you assigned is x1 but the PROM file (.mcs) is generated in a x8 mode. Please double check your assignments or it may not work properly.
iMPACT is right, I am using an SPI-Flash with 1 data line (S25FL128S). But I am out of ideas how I should tell PROMGEN how to create the .MCS-File otherwise. My command line is
promgen -w -p mcs -c FF -o FinalFiles\//generator.mcs -s 16384 -u 0000 "fpga-firmware.runs/impl_1/generator.bit" -spi
I have copied this line out of the .prm-File, which iMPACT has generated, and adapted the file paths. I have also added the option -g SPI_Buswidth:1 to the Bitstream Settings in PlanAhead. Now I am out of ideas.
Tags (3)
pratham
Did you go ahead and program the file anyway to check? There should be a way to generate a file using promgen. Please program the file and let me know your results.
-Pratham
pratham
@hardwareheini if you have-g SPI_Buswidth:1 then I think it should work, did you try?
if not working, please give it a try with -data_width 1 argument in your promgen command.
-Pratham
hardwareheini
Hi Pratham,
-data_width 1 did not work. Promgen complained: Command line error: Switch "-data_width" has invalid
value. Argument[7] "1" needs to match one of these keywords: "8|16|32".
Regarding the BITGEN-Argument -g SPI_buswidth:1 I have tried this repeatedly and it does not work. PlanAhead seems to understand the added flag. The log tells me *** Running bitgen with args "Generator_routed.ncd" "Generator.bit" "Generator.pcf" -g SPI_buswidth:1 -w -intstyle pa
I guess I have to use continue using iMPACT for this...
pratham
-Pratham
hardwareheini
I have flashed the .MCS-file I generated with PROMGEN successfuly into the FPGA and he is working as expected.
Christian
pratham
@hardwareheini Great! I was expecting this would work.
Please close this thread.
-Pratham
