Creating Block Design in Vivado 2018.2
I tried to creat block desing to add ILA.But when I click add module and select top module. I don't see any block diagram, and no error message too.
Design generates bit stream, but due to design changes on block that connect AXI interface of MIG (newly generated MIG), I need ILA to help in debug.
Can someone please help? What is the issue with Vivado, , why it does not show block diagram? Even "Add to block design" is greyed out in "Sources" window though "Block Design" window is open.
Raghav
Re: Creating Block Design in Vivado 2018.2
Hello @raghavs
Thank you for reply.
If you don't mind, please close this thread, kudo and accept as solution.
If there is anything more, please post a new one.
Hello @raghavs
Can you share your Vivado view and Block Design?
Thank you
Hi @katsuki ,
I took different approach of adding ILA as verilog module and connected the signals. Above is something that was issue though.
I could proceed ahead.
Raghav
Hello @raghavs
