Newbie dana_vainer
DFT for 25,000 points
I want to implement DFT fot N=25,000 points.
At the "LogiCORE IP Discrete Fourier Transform v4.0 Product Guide" I see that N can't be larger than 1536.
I can't use FFT, because i don't have 2^x samples, and i don't want to pad with zeros.
What do you recommend?
Re: DFT for 25,000 points
Core only supported FFT point size which mention in the product guide . For customize size contact XILINX FAE
Thanks and Regards
Balkrishan
Newbie dana_vainer
whst is FAE?
Field Application Engineer.
Generally the point of contact for Xilinx product sales.
Thanks,Vijay
Is this still an ongoing concern?
