benaka
Data logging
Hi everyone,
So I am reading the data from the XADC and want to transport the data to a log file (for example: .txt or .csv). Can anyone say how to do it? is there a way actually? I am using VHDL for the fpga development so far.
any help is appreciated.
Thanks in advance.
Tags (3)
anunesgu
Hi @benaka,
For viewing live internal signals such as the one you described, I'd suggest using the VIO and ILA IPs.
https://www.xilinx.com/products/intellectual-property/vio.html
https://www.xilinx.com/products/intellectual-property/ila.html
The document Vivado Design Suite Tutorial Programming and Debugging - UG936, Lab 3 and Lab 5, have an example of using such IPs for signal visualization and debugging.
Andre Guerrero
Product Applications Engineer
dpaul24
@benaka,
In my opinion the simplest way would be to get an UART core inside the FPGA to transfer your digitized data to the PC. After that getting them saved in a text file is easy.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
bruce_karaffa
@benaka
@dpaul24is right.  The UART is an easy and flexible way to export your data to a file.  One other way is to capture the data in an ILA and export the ILA data.  You will be limited by the depth of the ILA, but this is also a fairly easy method.
anunesgu
Hi @benaka,
You can print on the TCL console (and also print it into a txt file) the results from the XADC by using the command:
get_property ATTRIBUTE [get_hw_sysmons]
The attribute is the name of the parameter you want to see the current value, for example:
get_property VCCAUX [get_hw_sysmons]
To get the name of all the available XADC parameters, use the command:
report_property [get_hw_sysmons]
To make it behave more like a data logger, you'd need to make a script with a for loop that gets executed every X seconds (or ms) , and inside you can use a clock command to print the current system time, and then print the values of the parameters you need.
One example would be the script below. For 10 seconds, it will print the current time and the VCCINT current reading.
proc write_xadc {i} {
	set systemTime [clock seconds]
	puts -nonewline [clock format $systemTime -format %H:%M:%S]
    puts "  $i"
    flush stdout
proc do {end_time} {
    set end 0
    while {$end < $end_time} {
        after 1000
		write_xadc [get_property VCCINT[get_hw_sysmons]]
        incr end
do 10
Hopefully you can modify it for the application you need.
Andre Guerrero
benaka
HI @dpaul24,
I am using the DRP interface for the XADC. Now Is it still possible to use the AXI bus?
benaka
Hi @anunesgu
You explained well and seems more apt solution for my task, but are there any examples for reference. Vivado is new to me and TCL console is further new, may be a example will help me understand better.
Thanks for understanding.
dpaul24
@benaka,
No it has no AXI, it is only having native interface.
https://www.xilinx.com/support/documentation/user_guides/ug480_7Series_XADC.pdf
btw - Why do you want to use an AXI bus?
You can easily find a free UART core having a non-AXI i/f and drive it after writing a bit of your own interfacing logic, a small state-machine or something like that.
anunesgu
Hi @benaka,
So, to view the info from the XADC, you have to be in the HW Manager, looking at something like this:
If you look at the bottom of the screen, you will see the TCL console. You can actually see that some commands have been run already (anything you do on the GUI gets converted into a TCL command).
So, from the TCL console, you can run Vivado specific commands. One set of commands are related to reading data from the XADC (such as the get_property VCCINT [get_hw_sysmons] that I mentioned on my prvious message).
So I made the attached script called XADC_logger.tcl.
If you open this file, you will see there is a process (or function) declaration, as below:
proc write_xadc {end_time} {
	#Set here the directory and file name
	set filename C:/Users/anunesgu/Desktop/XADC_dump.csv
	set fileId [open $filename "w"]
	set end 0
        #the number 1000 indicates the loop will be run every second (1000 ms).
		#If you need a higher or lower frequency, adjust it.
		after 1000
		puts -nonewline $fileId [clock format $systemTime -format %H:%M:%S]
		puts -nonewline $fileId ","
		#this is the XADC properties that you want to have printed.
		#Add as many as you need.
		puts -nonewline $fileId [get_property VCCINT [get_hw_sysmons]]
		puts -nonewline $fileId [get_property TEMPERATURE [get_hw_sysmons]]
		puts $fileId " "
		flush stdout
        incr end
	close $fileId
You will have to change a few things it it, such as:
- Right on the top of the script, there;s a line declaring the filename. Change that to the location and file name you desire.
- The frequency that you want to log the data (every 10ms, every 1s, every minute, etc.) by changing the parameter after 1000.
- The name of the XADC parameter that you want to use (on this script, I added VCCINT and TEMPERATURE. You can add as many as you want)
You can save it somewhere in your computer, and once you're done edditing it, from the TCL console you can enable it using the following command:
source c:/Users/anunesgu/Documents/XADC_logger.tcl
Off course, change the path above to the one where you saved the file.
Now that Vivado session has a new command called write_xadc
So now from the TCL console, you can call that function by typing write_xadc 10 (the number 10 can be changed to whatever number, it's the number of seconds you want to run the scripts).
You will see a screen like this:
Once the processing popup goes away, you can open the file that was created with notepad or Excel. It will have something like this:
13:47:53	1.004	31.4
13:47:54	1.005	31.4
13:47:55	1.003	31.5
13:47:56	1.006	31.6
13:47:57	1.006	31.7
13:47:58	1.006	31.6
13:47:59	1.004	31.5
13:48:00	1.006	31.5
13:48:01	1.003	31.5
13:48:02	1.006	31.6
13:48:03	1.003	31.7
13:48:04	1.006	31.6
13:48:05	1.004	31.7
13:48:06	1.006	31.3
13:48:07	1.005	31.7
13:48:08	1.006	31.6
13:48:09	1.006	31.4
13:48:10	1.006	31.5
13:48:11	1.006	31.6
13:48:12	1.005	31.7
Observe it is the a log of the VCCINT and TEMPERATURE every second for 20 seconds.
I believe from here you will be able to easily modify this script and get what you need to do.
I suggest you first run it as is, without modifying anything and learn how it works.
Thanks!
Andre Guerrero
benaka
Hi @anunesgu , Thank you for the example. I will run as it is first as you mentioned and know more about it. also , I have another question, is it possible fir the processing to be seen live ?
For example I have this code which will get converted data from the address '0000011'(Vp_n_addr) when end_f_conversion of the XADC goes high.  and extract the actual data when DRDY signal goes high. So now I have store the data in
decode_sig <= master_volt;
ports..
archi...
signals
constants
read_xadc: process(clk)
begin
if rising_edge(clk) then
--read converted data when high at 'eoc' pin, with enabling drp and address;
if i_eoc = '1' then
o_den <= '1';
o_daddr <= vp_n_addr;
end if;
-- read the actual output data;
if i_drdy <= '1' then
master_volt <= in_do;
end if;
end if;
end process;
end Behav;
so now i have to see the data decode_sig at every certain interval live on a console are there any options or input you can provide?
Thanks in advance.
anunesgu
Hi @benaka,
Andre Guerrero
vilashini
set filename C:/Users/Vilashini/Desktop/XADC_dump.csv
set end 0
after 1000
puts $fileId " "
flush stdout
incr end
close $fileId
write_xadc 10
I have tried the above script. But the values of VCCINT and TEMPERATURE are not changing.
anunesgu
Hi @vilashini ,
Since this thread is already closed, if you need help in debugging your script, please go ahead and post a new thread.
Thank you,
Andre Guerrero
wgabor
Yes, this thread is closed, and yes, this is necropost, but since Google finds this topic and I needed the solution here it is:
You should do a refresh_hw_sysmon before readout, similarly to:
while { 1 } {
  refresh_hw_sysmon [get_hw_sysmons]
  after 1000
  puts [get_property TEMPERATURE [get_hw_sysmons]]
