08-08-2014 04:18 AM
I have an Artix design in Vivado 2014.2. It has an ILA and VIO cores that I created using the IP catalog and instantiated in the design. When I program the board I get the following error. Can someone tell me what this means?
WARNING: [Labtools 27-147] vcse_server: No CseXsdb register file specified for CseXsdb slave type: 0, cse driver version: 0. Slave initialization skipped.
ERROR: [Labtools 27-147] vcse_server: Data structures not initialized for CseXsdb slave Device:0, user chain number/bus:1, slave index:0.
ERROR: [Labtools 27-1829] vcse_server failed during internal command 'CseXsdb_getRegisters'. See previous error messages.
08-08-2014 04:22 AM
Sometime back in 11.s, These are spurious messages that can be ignored. The errors occur when the device is reset with a PROG pulse or Power Cycle and then a reconnect is attempted.
To work around this issue, reconfigure the device. Can you check if this still helps with Vivado?
Sikta
08-08-2014 04:50 AM
08-09-2014 02:20 AM
08-11-2014 07:15 AM
