Error while using Chipscope Pro in ISE 14.7 for Spartan3E
ERROR:NgdBuild:76 - File "F:/APUF_June6_2/hardMacro_2.ngc" cannot be merged into
ERROR:ChipScope: Could not execute NGCBUILD to create F:\APUF_June6_2\macro_cs.ngc
I am getting this error while I am trying to open .cdc file. I have hardmacro instances in the verilog module . Is it the reason I a getting the error?
Re: Error while using Chipscope Pro in ISE 14.7 for Spartan3E
Hi swatisaj@buffalo.edu ,
What would be the rest of the error message (after the "cannot be mergerd into...")?
I found the following ARs that are related to this error. Could you please take a look and give it a try to see if any of them helps you?
https://www.xilinx.com/support/answers/31110.html
https://www.xilinx.com/support/answers/36359.html
https://www.xilinx.com/support/answers/8205.html
https://www.xilinx.com/support/answers/45864.html
Please let us know if any of them worked or if you still require further support.
Thank you,
Andre Guerrero
Product Applications Engineer
