zan_zhan@amat.com
FPGA XCKU5P fails to boot from QSPI Flash when JTAG is hooked with Laptop
I have a board with XCKU5P and is suffering from an odd issue.
when I hooked the board to may laptop(with Vivado) by Jtag, and power cycle the board, the board fails to boot from QSPI Flash.
Do you guys have seen this kind of issue before.
Best,
hj
Follow this AR https://www.xilinx.com/support/answers/66954.html
Harshit
For more information please refer to configuration resources https://forums.xilinx.com/t5/FPGA-Configuration/Configuration-Resources/m-p/753763/highlight/true#M5891
hj
Harshit
