FPGA cannot connect to Cable
When I used cable for the Program FPGA in the SDK, I found that I could not successfully download the bit.
I am sure that my cable has no problems, the LED has turned green, and I have successfully connected to the board in Vivadoand can successfully download the bit
6.JPGHow do I program FPGA in the SDK?I also found that Program Fash Memory is the same situation, can not Detect device
Re: FPGA cannot connect to Cable
Cable which you have posted in the last post doesn't seems to be Xilinx original cable. Please use the Xilinx cable or Digilent JTAG cable and share the findings.
Original cable
Harshit
Hi Yangkejian, programming an FPGA with a bitstream can involve several components.  Let's start with some basics, even though this seems tedious.
Which FPGA board are you using.  Does it have a revision number?
Which version of Vivado and the SDK are you using?
What type of cable are you using?
Where are the ends of the cable connected?
Have you been able to program this FPGA with another design?
Have you been able to program a different FPGA with your currently installed Vivado and SDK?
I hope to hear from you soon.
Which FPGA board are you using.  Does it have a revision number?           ZYNQ-7000    xc7z010clg400-1
Which version of Vivado and the SDK are you using?                                  2018.2 / 2017.4   Both versions have tried
Where are the ends of the cable connected?                                               One connected to the usb interface of the notebook, one connected to the boad
Have you been able to program this FPGA with another design?                 Tried multiple designs,and the situation is exactly the same
Have you been able to program a different FPGA with your currently installed Vivado and SDK?   As long as  need a cable,  can't Program FPGA.
Original cable
Harshit
@yangkejian I love the strategically-positioned thumb to stop everyone seeing the missing "Xilinx" brand on that dodgy cable.
As has been said above, try getting a genuine cable (Digilent counts as genuine - the Digilent HS3 is not very expensive).
