Visitor edmundtan
How to drive pre-assigned input via VIO
Hi all,
I am a beginner with VIO Chipscope.
Is it possible to drive a pre-assigned input via the VIO synchronous output without using TCL script?
Thank you very much!
Visitor edmundtan
Re: How to drive pre-assigned input via VIO
Elaborating further, can I pre-assign a VIO output then send it serially out via its synchronous output port?
The list of  TCL commands for the VIO core can be found from Pg 195 of this user guide - http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/chipscope_pro_sw_cores_ug029.pdf. Please check and see if you cam find what you are looking for.
Anirudh
Community Manager
Community Manager
We don't have an option in the VIO core to specify the initial value on the outputs in ISE. But we do have that option in Vivado i.e. in VIO core v3.0.
Assign the desired value to the sync output and save the chipscope project. Each time you open the project, the output will be configured with the assigned value.
Please try this and let me know if it works.
Krishna
Visitor edmundtan
Guess I have to use TCL scripting then. I am using ISE and ISE VIO only has a rigid way of inputting train pulses. I am inputting a 128 to 255 bits input serially; it will take me forever to manually do that.
The below link documents also add some useful information
http://www.xilinx.com/support/documentation/ip_documentation/vio/v3_0/pg159-vio.pdf
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_3/platform_studio/ps_p_dbw_configuring_cs_vio_cores.htm --follow chain of links
