07-31-2018 01:12 AM
I had marked an AXI Lite connection in the block design for debugging. I'm seeing that the AWADDR probe is missing from both the schematics and in ILA probe.
After synthesis, I have setup debug for all the AXI Lite signals but not sure why some of them are either split and AWADDR is missing . Did anyone face similar problems?
Vinay
07-31-2018 01:27 AM
No.
Remove core, re-insert core and try again.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
08-13-2018 10:55 AM
