ILA waveform window disabled
Vivado Version: v2014.4.1 (64 bit)
I have two ILAs in design. Hardware manager is connected to the board.
This may be a trivial miss. I am not able to add probes to waveforms.
Error Message: There is no current wave configuration. You must trigger and open before adding probes.
The open waveform for this ILA core button is also disabled as shown in attached image.
Re: ILA waveform window disabled
hi @vemulad @arpansur
Appreciate your quick replies.
I am making custom changes to a reference design. I figured out that such behaviour is observed when one of the unused ILAs in reference design is removed. When it is placed back everything works fine as expected. Surpisingly, no warnings from HW Manager.
thanks.
I have added the trigger condition and also did an immediate trigger.
Hi @sibythachil
In the waveform window of ILA, click on + sign shown below and add the probes
Deepika.
Hi @sibythachil,
Can you please  verify if the waveform is checked in the dashboard?
Arpan
Arpan
@vemulad Thanks for the quick reply.
I am not able to open the waveform window itself.
1) As in the image I have attached the open waveform button itself is disabled.
2) If I right click on signals and try to add probes to waveform , the error message pops up. The waveform window does not open.
@arpansur
In Vivado 2014.4.1 I do not see options to enable waveform as you have highlighted.
 hw_ila_1 -> right click -> Open Hardware Dashboard -> ILA properties window, Trigger Capture Status and Basic Trigger Setup.
No option such as "Dashboard Options"
Hi @sibythachil,
Can you please verify if WCFG file is created in the folder location <project_folder>/<project_name>.hw->hw_1->wave?
Arpan
Arpan
Hi @arpansur,
Yes. The wcfg and wdb files are created for the 3 ILAs I have.
thachil
thanks.
