ISE14.6 , I cannot open the core generator, any idea?
Dear all:
when I double click the block ram IP in the project, the GUI for the IP configurations does not appear. The status bar shows "openning: blk_mem_gen_0.xco"(as showed in the following image). When I try to close the ISE, it saying that a process is running and refuse to be closed. I try to stop the process by "Process -> Stop", but it does not make any sense. Any idea ?
(My operating system: centos 7.1 x64)
Re: ISE14.6 , I cannot open the core generator, any idea?
Hi @fanxitian,
CentOS 7 is unsupported OS for ISE 14.6. Please refer to page 7 of this link for supported OS:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_6/irn.pdf
Also, see if this forum post that addresses running ISE versions on unsupported OS, helps you in running coregen successfully in CentOS 7:
https://forums.xilinx.com/t5/Implementation/ISE-13-1-MAP-crashes-on-Ubuntu-11-04/td-p/156398/page/2
Nupur
hi,
can you try it in one of the supported OS?
http://www.xilinx.com/support/answers/18419.html
--hs
Hi @fanxitian,
Nupur
I have solved this problem by removing the definition of the variable "LD_PRELOAD" in bashrc. Thanks!!
hi,
that is good to know. can you mark this post as solved? this might be useful for other users.
--hs
