Participant lanxiang.ben
Ila debug core Programmer problem
Hi All
        How to handle this problem?
        Please examine the ancessory
BR
lanxiang
Re: Ila debug core Programmer problem
ILA input clock is constraint properly?
Is your design meeting all timing requirements?
Yash
Please check this AR
http://www.xilinx.com/support/answers/52939.html
Thanks,Vijay
Yash
Hi @lanxiang.ben Is your issue solved? Please mark that helped you as solution.
Thanks,Vijay
hi,
I have fixed it by Installing vivado- v2013.2 and just slower the JTAG frequency to ensure it is slower than my ILA frequency.
But I have another question: I can not change the JTAG clock in vivado 2014.1, why ?
