thor-00
Isim is missing or does not work
Hei!
I just installed xilinx ISE 14.4 webpack but when I want to simulate behavioral model In ISE project navigator then nothing happens, ISIM does not start. In console window there are "Process "Simulate Behavioral Model" completed successfully"
So how to fix that problem??
PS I have windows 7 64bit OS and my friend has the same OS but ISE v 12.2 and he has no such problem.
vuppala
Try out below suggestions:
1. Disable anti-virus and try running simulation.
2. Clean Up Project files and try again.
thor-00
Hei!
I tried both things, didn't help (I use MS security essentials as my friend does).
I even tried to reinstall xilinx but nothing, now I even do not find isim.exe program from my computer :S
thor-00
OK, there where a update and now I found isim...exe from my computer but still, after simulating isim does not start
thor-00
So no solution jet? Everyone? I have one project where isim start, but even if I copy this project, isim would not start enymore...
