Labtools 14.7 ibertplotter example csv file
I have software to collect the statistical eye pattern from a Xilinx Virtex 7 GTX SERDES.  I want to display this data using the Xilinx 14.7 Labtools ibertplotter but can't seem to get the format correct.  I am looking for an example .csv files that this tool reads so that I can create my own version.  Doesn't one have a csv that works?
Mike
There is an example in the thread below.  Not sure it has maintained the format between versions but that is likely what they tried to do.
https://forums.xilinx.com/t5/Serial-Transceivers/Displaying-a-Statistical-Eye-plot-using-Manual-Eyescan/m-p/1098257#M7591
I believe that this is a file for the Vivado tools and not the older ISE.  It doesn't load with the 14.7 ibertplotter.exe.
I get the this error message.
Loading CSV file: C:\XXXXXXX\test.csv ...
File C:\XXXXXXX\test.csv does not have valid info to plot.
