Probe interface ports
I have an external interface to block design. Say a vid_io interface. It connects to a Xilinx IP which has vid_io interface. So I am unable to connect an ILA to probe the signals.
The below discussion says expand the ports. But the external port interface does not expand to the sub-ports.
https://forums.xilinx.com/xlnx/board/crawl_message?board.id=OTHER&message.id=7382
How to I probe the signals in vid_io interface ?
Many thanks,
Pujyan
Re: Probe interface ports
Hello Pujyan,
Instead of manually inserting an ILA like that (I never ever do that, personally), just right-click the net or bus and select 'Mark Debug.' This will automatically insert the ILA and it will show up when you go to set up the debugger post-synth.
www.xilinx.com
Hello @bwiec,
I tried that also. When the bitstream is loaded on to the fpga
"ERROR: [Labtools 27-1973] Mismatch between the design programmed into the device xc7z020 (JTAG device index = 1) and the probes file debug_nets.ltx. The device core at location user chain=1 index=0, has 5 ILA Input port(s), but the core in the probes file has 9 ILA Input port(s)."
https://forums.xilinx.com/xlnx/board/crawl_message?board.id=OTHER&message.id=9493
It is kind of a stalemate. Any help is much appreciated!
-Pujyan
Hi @sampujyan,
It seems you tried changing the number of signals probed to ILA
Please go through http://www.xilinx.com/support/answers/66860.html
Arpan
hi @arpansur @bwiec
thanks for the pointer. But the problem still persists. Only 5 out of 9 ports remain in the bitstream. Tcl command report_debug_core shows all 9 ports!
Is there any way to know which ports are optmized away ?
-Pujyan
Hi @sampujyan,
Please attach the .ltx file.
Also can you please try opening implemented design and use
write_debug_probes -force filename.ltx
Arpan
hi @arpansur
ERROR: [Labtools 27-1973] Mismatch between the design programmed into the device xc7z020 (JTAG device index = 1) and the probes file debug_nets.ltx.  The device core at location user chain=1 index=0, has 5 ILA Input port(s), but the core in the probes file has 8 ILA Input port(s).
Attached is the debug_nets.ltx
-Pujyan
Hi @sampujyan,
Which version of Vivado are you using?
Is it possible to check in latest version of the tool?
Also can you please share the design file?
Arpan
This error means the bitstream you programmed into the device is not the same one that you put the debug nets into. I will see this message if, for example, I insert my debug probes in Vivado and generate a bitstream but forget to export it to SDK. Then when I download the stale .bit from SDK and then open the Vivado GUI to look at the traces (which uses the new debug.ltx), the error will occur.
www.xilinx.com
@arpansur
Sorry, sharing the src code is not an option right now. I am generating the bitstream in Vivado 2016.1 and remotely connecting hardware manager to a lab PC which is on 2015.3. I reduced the JTAG clock freq to the minimun and ensured clocks are free running.
@bwiec
I am not using SDK. Steps I follow are
1) open the block design
2) Mark video_io interface for debug
3) Synthesize
4) Setup debug on synthesized netlist
5) Generate bitstream
6) Verify timestamps of both debug_nets.ltx and .bit files and load both to a Zynq fpga connected remotely
Am I missing something ?
-Pujyan
I've just faced the same issue.
Project is made in 2016.2.
When I try to debug in 2015.3 - error occurs.
But after upgrading debug machine to 2016.2 - it dissappears.
Thanks for sharing @g.pavlikh. I got around by moving the hw to my desk :)
