Prasanna_K
Trigger ILA based on AXI signals in TSM [ILA]
I am trying to compare two AXI signals ARADDR(40 bit) and RDATA(128 bit) together in a conditional statement, where ARADDR and RADTA have same values, I know these signals have different sizes 128 and 40 bit.  But I want to compare these two signals and trigger ILA when their data doesn't match.
So I want to understand, How do I compare these two signals?
1. Is there a way to concatenate and make 40 bit ARADDR to 128 bit?
2. Or convert 128 bit data to 40 bit just for comparison?
3. How to compare RDATA(40 bit) with a ARADDR(40 bit), I have sliced the RDATA width from 128 bit to 40 bit? I have copied the code below(CODE 1).
4. How to compare RDATA(16 bit) with a counter value(16 bit), I have sliced the RDATA width from 128 bit to 16 bit? I have copied the code below(CODE 2).
My code and the error have been copied below.
 Code:
CODE 1: Comparing 2 AXI signals:
state byte_read_1:
 if (bd_design_0_i/system_ila_0/inst/net_slot_1_axi_rdata != bd_design_0_i/system_ila_0/inst/net_slot_1_axi_araddr) then
  trigger;
 else
  goto byte_read_1;
 endif
Error:
[Labtools 27-2053] Error encountered during parse: syntax error, unexpected IDENTIFIER 'bd_design_0_i/system_ila_0/inst/net_slot_1_axi_araddr' ["/mnt/work/kotrappa/zip_fpga/zip_ip/project_1/txns.tsm":7]
CODE 2: Comparing AXI signal with counter:
state byte_read_0:
 reset_counter $counter1;
 goto byte_read_1;
state byte_read_1:
 if ($counter1 != bd_design_0_i/system_ila_1/inst/probe1_1 ) then
  trigger;
 else
  increment_counter $counter1;
  goto byte_read_1;
 endif
Error:
[Labtools 27-2053] Error encountered during parse: syntax error, unexpected IDENTIFIER 'bd_design_0_i/system_ila_1/inst/probe1_1', expecting BINARY_CONSTANT or HEX_CONSTANT or INTEGER_CONSTANT or DONT_CARE_CONSTANT ["/mnt/work/kotrappa/zip_fpga/zip_ip/project_1/txns.tsm":6]
Any suggestion would be gratefully received.
Prasanna
Tags (3)
