Upset about ISE IMPACT Program Fail
I have a program fail problem on ISE IMPACT.  It happens often.
How to fix it?  I can now just try it by chance.  Very upset about it.
Peter Chang
Re: Upset about ISE IMPACT Program Fail
@peterchang0708 I belive your problem is with the INIT_B or PROG_B being pulled down. Please check this AR
http://www.xilinx.com/support/answers/34599.html
-Pratham
Note that INIT_b is also 0, indicating a CRC error,
Check the signal integrity of the CLK and DATAIN lines.  Poor impedances, improper drive or termination may cause bit errors due to bounce or ringing.
Austin Lesea
Principal Engineer
Xilinx San Jose
Hi Austin,
Thanks for your recommendation.  I've breifly checked the TDI, TCK, TDO and TMS.
It is hard to understand the data content.  Threre are some photos attached.  Those
are the jtag signals that I probed.  Including zoom-in and zoom-out waveforms.
I've used the FPGA for several months.  It happens sometimes.  But this time, it seems
not able to problem any more.  I've spent about one day to try.  You mention about the
poor impedance, improper drive and termination.  How to improve the impedance?
About the drive, you should mean the JTAG cable from the PC with ISE iMPACT.
I don't change any drive, I think.  What does the termination mean?  Thanks.
Peter Chang
jtag_00.tif
jtag_01.tif
jtag_02.tif
jtag_03.tif
jtag_04.tif
Hi Austin,
One question about the INIT_b status.  You mention that it indicates an CRC error that I should pay attention to.
In my case, I use JTAG to program FPGA.  We don't use INIT_B.  Will the status register be also valid?
Should I check the readback, post_crc_init_flag, or post_crc...and so on?  Thanks.
Peter Chang
Hi Austin,
What I mean for that I don't use INIT_B is that I don't use the INIT_B pin to indicate a CRC error.
I use it for general I/O pin.
Peter
Hi Austin,
A configuration log is attached for reference.
Status registers are all 0.  It isn't normal.
But I don' t know why?  It still doesn't work.
Peter Chang
Before DONE goes high, INIT_b indicates the status of the CRC check of the configuration,
Yours has failed, so no DONE.
Austin Lesea
Principal Engineer
Xilinx San Jose
Hi Austin,
Thanks for your comment.  From the status registers, I think not only INIT_B, but also
some are others, for example HSWAPEN.   All registers are zero now.  How to make it
to be one?
Peter Chang
-Pratham
Hi Prantham,
Thanks for your information.  It is useful.  but it may not the case I met.
I thought the chip may be broken at the DONE pin, accroding to a Xilinx
staff's description.  According to his description, the DONE pin is weak,
becasue of open drain.  I don't know the strength yet.  But I've used hand
to touch it and multifunction meter to drive the LED at its output.  I guess
it may cause some damage.  Otherwise, we don't have any other reason,
so far.
Peter Chang
@peterchang0708 I believe so
-Pratham
Dear Pratham,
Thanks for all your kindly help.
Peter Chang
@peterchang0708 Please close this thread.
-Pratham
