benjamin.blase
Vivado 2016.5 no remote hosts settings
I'd like to configure Vivado to use remote hosts, but the setting simply does not appear in the options menu:
What am I doing wrong?
florentw
Hi @benjamin.blase,
You need to be on a Linux OS to use remote hosts.
From UG892 (link), p51:
Florent
Florent
benjamin.blase
I mean Vivado 2016.4 of course...
florentw
Hi @benjamin.blase,
Florent
Florent
benjamin.blase
I'm using the Vivado 2016.4 System Edition.
benjamin.blase
I'm using a Windows Client. The remote host is a linux workstation.
