bomba_rcs
Vivado: Cannot Export Hardware .sysdef does not exist
Hi all,
while trying to export my Vivado Hardware Design I came up with the error message you can see in the attached picture.
I want to include the bitstream I created a step before and export the whole design. What do I do wrong?
Thanks in advance!
bomba_rcs
Randomly I figured out that moving the project folder into the directory of the Vivado installation folder fixed the problem. Probably I had some issues which r/w rights in my personal folder at work.
Mabye this hint will help others.
pratham
@bomba_rcs What Vivado version are you using? Device? Can you reset the run give a try again?
-Pratham
bomba_rcs
I am using Vivado 2014.4 with Windows 7. My device is Zynq 7020.
I already tried an reset a lot of times but it did not help.
pratham
@bomba_rcs Strange. Can you upgrade to vivado 2015.3 or attach your design here if you dont have any problem?
-Pratham
bomba_rcs
I will upgrade to vivado 2015.3 in the near future and report my results here. Thanks for helping!
bwiec
Does it work if you uncheck the 'include bitstream' option?
This may be a silly question... but do you have a Block Diagram in your design and a processor (PS7 or microblaze)?
www.xilinx.com
bomba_rcs
Yes, it works if I uncheck the 'include bitstream' option. But for further use I need the hdf-File with included bitstream.
I attached the design of my Block Diagram.
pratham
@bomba_rcs Did you get a chance to try this 2015.3? I would appreciate if you could archive project and attach here?
-Pratham
bomba_rcs
