What is the default frequency of CCLK in ICAPE2
Dear All
    I want to know what is the default frequency of CCLK in ICAPE2?
    I can't find the massage in UG470 and 7series_hdl.pdf
BR
lanxiang
you need to provide the clk signal to the icap, check for the max spec in the datasheet for the icap clock
http://www.xilinx.com/support/documentation/data_sheets/ds182_Kintex_7_Data_Sheet.pdf
--Krishna
Community Manager
Community Manager
Are you referring to input clock CLK of ICAPE2?
Krishna
Yes
BR
lanxiang
.CLK(CLK), // 1-bit input: Clock Input
--Krishna
