robert_ko
XPE 14.3
Seeing weird issue using this XPE for Excel 2010.   I need it because I'm using virtex 5.  When I update Junction Temp, I can update it successfully to 50 for example using override checkbox, but if I click on any other tab, it resets the temp to 100.   I can actually see that tab at the using correct value on the Temperature graphs for a split second before it resets.
I know it is listed as supporting 2003,2007, but it is 2017 and Virtex 5 users need something usable
austin
Found the issue.  Reported.  Looks easy to work around however,
The workaround is to override Tj, set your temp,
then uncheck the box and it will keep that temperature.
Then you can click on the graphs tab and it will be correct.
Austin Lesea
Principal Engineer
Xilinx San Jose
austin
Just downloaded it, and it works fine for me.
Austin Lesea
Principal Engineer
Xilinx San Jose
austin
Austin Lesea
Principal Engineer
Xilinx San Jose
robert_ko
Confirmed works for Excel 2010
