Xilinx Platform Cable II is not working
I am working on Vivado 2016.3. The software was working fine with downloading using USB Platform Cable II.
But after using it on another machine the patform cable is not at all professional.
Now when I connect it to my PC there is a repaeted sound (like make break) that USB has been detected
There is no LED neither yellow or green seen on the cable now
Please suggest a solution
uzmeed
Re: Xilinx Platform Cable II is not working
Check it on another computer and board and new USB cable.
Sounds like either the cable has broken, the unit has been fried, or the board is broken,
Cracky sounds from the platform cable... it can only sound to a funeral march I'm afraid...
I had lots of problems with that thing. I had to wipe a computer and reinstall from Windows just because of that thing not wanting to work anymore after a Vivado upgrade. That on top of several hours spent on trying to fix it.
I'm now using the Digilent HS3. Far more reliable.
Hi @drjohnsmith
I tried every option and every possible combination
from trying different cables ,different machines to reinstalling the derivers
But nothing worked
Some that is most wiered is that I had another cable that was not working with my laptop. I just took another cable that was working with desktop and connected to laptop; second cable also stopped working with same behaviour
uzmeed
