adiscb@gmail.com
bootgen coomand
Hi Sir,
           When i am running the command  below on Xilinx SDK 2014.3.1 COMMAND Prompt:-
          bootgen -image ../Sources/partial.bif -w -process_bitstream bin
          it is giving the error shown below:--
          Fatal: Exception : Can't read  the file "../Sources/partial.bif"
          Please help me to figure out this.
          Aditya
pratham
adiscb@gmail.com
Looks like the file is not present there. Can you copy the bif file in the PWD and run the command?
bootgen -image all.bif -w -process_bitstream bin
-Pratham
balkris
you can check steps here
http://www.wiki.xilinx.com/Solution+ZynqMP+PL+Programming
Thanks and Regards
Balkrishan
adiscb@gmail.com
I did that but i am getting the same error.
pratham
Can you attach the .bif and its content here so that I can try and update you? I don't think this is an issue with the bootgen command.
-Pratham
