Observer chienpingwong
can Chipscope automatically "Run" after loading bit file
Usually when using Chipscope, we need to press "Run" botton to trigger whole procedure. But what if the condition I want to see  is immediate right after FPGA boots up. Then for this reason, I need to ask if there is any setting can automatically trigger chipscope to run after loading bit file into FPGA. Thanks you.
Re: can Chipscope automatically "Run" after loading bit file
Yes. We have this feature in Spartan-6, Virtex-6 and newer devices. It is called the startup trigger. To learn how to use this feature, please look at the ChipScope users guide:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_4/chipscope_pro_sw_cores_ug029.pdf
Please refer to the "Startup Trigger Run Mode" on pg 75.
